Hi, forum
As a contractor we are in charge of detailed design of a HC vacuum tower revamp. Licensor specified to replace the bottom pump with a new one, but unfortunately pump was purchased with more capacity than required and during some cases we have capacity less than min stable flow. We can do nothing with this pump and shall apply spillback to pump suction - to tower bottom. And we can't make appreciable changes in tower design. We have a problem - from one hand we shall make a spillback, on other hand we shall not make big changes in tower design or we face problems with licensor. Can anyone helps us? Any worth sources will be appreciated.
General figures:
- liquid - gasoil
- pump suction flowrate (normal) - 90 m3/h
- pump suction flowrate (pump best efficiency point) - 196 m3/h
- pump min cont stable flow - 40 m3/h
Q1: How can we put pumped liquid back to bottom in so way that:
- spillback doesn't produce many bubbles and these bubbles aren't carried by liquid flow to pump suction nozzle and cause a cavitation
- spillback isn't carried to liquid outlet nozzle and heated liquid isn't sucked straight back to pump
We can't put a big distributor to tower bottom since it can interrupt bottom tray to work properly. Anyway licensor wouldn't be happy to see any changes but the less changes we make the better. The best it would be just another one new nozzle in the tower bottom.
Q2: (concerned not only this case)
Are there any recommendation/practices/rules etc. for vessel nozzle diameter? Any type of vessel:
- towers
- separators
- storage tanks/vessels
- buffers/depulsators/recievers etc.
Any type of fluid and nozzles:
- liquid/vapor inlet
- liquid/vapor outlet
- two phase inlet
Any advice or opinion would be appreciated - I understood in general forum members are experienced in refinery/chemical processing. But please note that potentially we already have a problem with licensor and any competent sources would be extremely worth in this case. Anything we could use in correspondence.
Edited by shvet, 14 January 2017 - 02:01 AM.
