Homogeneous Reactors Question Help
plug flow reactor homogeneous reactor equilibrium reaction
#1 firefox23
firefox23
  • 17 posts
Posted 29 January 2017 - 06:56 AM
Attached File  IMG_1114.JPG   134.62KB   0 downloadsHi, I am struggling with a homogeneous reactors question and would much appreciate any help! the question I have attached as a image and all of the other information I have been give for the question i have also attached. I have the values for Xmax from a previous question and i have values for K1 at different temperatures. The reactor can be modelled as PFR and so i performed a mole balance over a small element dV to get the volume of the PFR as can be seen in the image. I also calculated molar ratios of all reactants and products and multiplied by P to get partial pressures. I then subbed these in to get the integration as shown. I am using excel and so used trapezium rule to solve the integration however the graphs i get for temperature vs. volume does not seem right and the values for volume seem much too low. Any ideas what i might have done wrong? I've also attached the graph i got for volume against temperature.Attached File  IMG_1102.JPG   91.09KB   1 downloadsAttached File  IMG_1103.JPG   114.2KB   0 downloadsAttached File  IMG_1104.JPG   198.83KB   0 downloads
Edited by firefox23, 30 January 2017 - 01:13 PM.
#2 Mahdi1980
Mahdi1980
  • 182 posts
Posted 30 January 2017 - 12:19 AM
I have checked just your integration formula,
If your equations are true, you can check that there is a mistake in simplifying of the last statement of the integration.
the math statement within the integral to be :
        dx. (1+X).2K1/ ((1-X)2k1p - p^2.X^2)
but you have written an additional (1+X) in the denominator. It seems that by revising your formula, the volume will be higher.
Please check it and solve the revised formula and let me know the result.
Mahdi,
#3 firefox23
firefox23
  • 17 posts
Posted 30 January 2017 - 11:22 AM
Mahdi,
Hi, there is an extra (1+x) because of the (1-x)/(1+x) term. in order to have (1+x)^2 on the numerator I have to multiply this term by (1+x) so that I have (1-x)(1+x) on the denominator. Apologies I've just realised that the (1 +x)^2k1 looks like 2 x k1
Edited by firefox23, 30 January 2017 - 12:04 PM.
#4 Francisco Angel
Francisco Angel
  • 88 posts
Posted 30 January 2017 - 12:50 PM
Mahdi,
I agree with firefox23 regarding the integration term. As for your results, you could make and order of magnitude estimate considering a CSTR like this:
V_CSTR=F_EB_inlet * X / r
You could provide more details to help others check your work, like the details to calculate K.
Best regards.
#5 firefox23
firefox23
  • 17 posts
Posted 30 January 2017 - 01:15 PM
Mahdi,
Best regards.
Thanks, i'll try it with your suggestions. Details for k are now also attached to the main post
