Restriction Orifice Sizing
Posted 11 February 2017 - 03:22 AM
I was asked to size an R.O of nitrogen flow of 7 bar to let down the pressure to 1 bar keeping into consideration the nitrogen flow should be 25 Nm3/h. What calculation standard of R.O sizing do you recommend to apply?
Posted 11 February 2017 - 10:04 AM
To what standard will the RO have to comply with? My guess is . . . none, but you tell us.
Posted 11 February 2017 - 10:06 AM
If you search this forum you might find a download link to software that will size the RO. I remembered the link. Here it is.
http://www.mediafire...rifice_Flow.exe
Edited by Bobby Strain, 11 February 2017 - 10:15 AM.
Posted 12 February 2017 - 07:45 AM
Said,
Are you trying to verify the orifice sizing equation through some standard? If yes, orifice sizing equations can be found from a variety of standards. One very popular standard for orifice sizing for a variety of orifice configurations (square-edge concentric, square-edge eccentric etc.) is the following:
ISO 5167 Part 2: Measurement of fluid flow by means of pressure differential devices inserted in circular-cross section conduits running Full - Part 2: Orifice Plates
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Ro SizingStarted by Guest_T_bag_* , 27 Feb 2024 |
