Hey I would like to know how the amount of air supply(insufficient, stoichiometric, and excess) to a heater affects the combustion heat energy of the fuel, e.g methane or ethane.
Thanks in advance for your help.
Posted 23 February 2017 - 09:42 AM
Posted 23 February 2017 - 03:14 PM
Not in the least.
Posted 23 February 2017 - 06:24 PM
Consider the material attached .
Posted 23 February 2017 - 08:23 PM
The heating value of the fuel remains the same. However the amount of air affects the temperature of the flue gas and thus the temperature of the combustion side of the heater is lower. Therefore to get the same temperature in the process side, the amount of fuel required will be higher.
You should optimize the excess air. Typically we measure the O2 at the flue gas and try to keep it 3-5mol%. If the figure is say, 7%, it means we are providing too much air than necessary for complete combustion and the heater will be consuming more fuel.
Posted 26 February 2017 - 08:46 AM
What is the
When we provide too much oxygen, it will lower down the output temperature and lead to increase in fuel right? What will happen if we provide insufficient air for the combustion?
Posted 26 February 2017 - 09:36 AM
What is theHey I would like to know how the amount of air supply(insufficient, stoichiometric, and excess) to a heater affects the combustion heat energy of the fuel, e.g methane or ethane.
Posted 26 February 2017 - 09:54 AM
Another issue is that you can go into a "Fuel Rich" condition. This is a dangerous condition that may lead to an explosion if operators do not respond adequately. Search in google "fuel rich condition in fired heaters" there are some good articles listed.
Coefficient Of Conversion Of Electrical Energy Into Thermal Energy ForStarted by Guest_amx_* , 03 Apr 2024 |
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
