For the disposal water tank, I have observed a PSAL and no sign of PSAH on the tank. I'm failing to see how critical PSAL is with respect to PSAH. Why would we be MORE concerned to protect the tank from low pressure rather than high pressure? When there's low pressure, the following actions are taken:
1) Inlet is shut
2) Ejector is shut
3) Outlet is shut
Why are we closing the inlet? The last two seem to make sense but the first point doesn't.
I've also seen that for PSAH (in other schemes online), we tend to close the ejector. Isn't the ejector's purpose to 'reduce the pressure' so, why are we shutting it in case of high pressure.
Thank you.
