Hi All,
I have a control valve controlling the upstream of a column at 52barg. Depending on the throughput of the column, the control valve regulates the flow to maintain upstream pressure at 52barg.
Looking at the control valve datasheet, it only states a normal flow of 4225kg/hr, upstream P of 52barg and pressure drop of 10 bar. Cv calculated as 1.65. The design Cv specified seems to be 2.0
(Density = 800, temp = 150C)
My question is, can you from the above be able to work out what the maximum flowrate is through the valve when 100% open, and also the downstream pressure (upstream pressure remains constant).
If you can point in the right direction that would be great.
Thanks in advance
