Co2 And Water Adsorption From Air
Posted 09 April 2017 - 07:44 PM
Posted 10 April 2017 - 05:56 AM
The inlet air generally comes compressed at 5-6 bar(a), why are you saying it's at atmospheric pressure.
We use inlet velocity of 0.19 m/s , so your assumption is correct.
Bodhisatya.
Posted 10 April 2017 - 07:12 AM
Dear Bodhisatya,
Sorry, I wasn't clear. The air enters the plant at 36 ºC and 1 bar; but the air enters the TSA system at 6.9 bar. According to our simulation, the conditions of entry would be:
Posted 10 April 2017 - 07:29 AM
This sounds ok...Please share your work, will like to dig in and will let you know (if it's not breaching protocols).
Bodhisatya.
Posted 10 April 2017 - 07:32 AM
I'm uploading my calculation excel file so you can see it.
Posted 10 April 2017 - 07:35 AM
Where it says "Skeletal density" it's actually "Bulk density", sorry, my mistake.
Posted 11 April 2017 - 01:54 PM
Miguel:
If you really want worthwhile engineering help on your adsorption problem, you have to submit YOUR basic data and detailed calculations - not some computer printout results. Looking at your spread sheet, that is all that you show us.
Without a detailed explanation and calculations, our members can't decide if your results are valid, correctly done, or bad math, bad logic, or bad calculations. If you have really done the detailed calculations, then submit them with the details of your logical steps. But if you actually only resorted to using a simulation program to do your design for you, then your problem may be that you haven't inputted the correct data or that your program isn't suited to what you want it to do. No one can attest to the accuracy or validity of the simulation design you obtain except the people who sold the simulation package - and even they won't guarantee the correct results.
Posted 17 April 2017 - 07:30 AM
Dear Art Montemayor,
Thanks.
Miguel.
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Rapid Depressurization Of WaterStarted by Guest_golegolegole_* , 31 Mar 2024 |
Adsorption Bed Uprising Or CrushingStarted by Guest_Lyne_* , 09 Mar 2024 |
Water Seal Pot Of Prv Working PrincipleStarted by Guest_panagiotis_* , 23 Feb 2024 |
