Hi, I am currently designing a gasketed plate heat exchanger and I need to calculate the wall temperature in oder to calculate the viscosity correction factor. I know hotwto do this for a tube and shell heat exchanger but am unsure how to adapt the method I used to make it work for a gasketed plate heat exchanger. What is the area I need to use? Any help would be much appreciated.
Wall Temperature Of A Gasketed Plate Heat Exchanger
Started by firefox23, Apr 15 2017 10:25 AM
plate heat exchanger wall temperature chemical engineering design
Caloric Temperature CalculationStarted by Guest_bckesim_* , 10 Apr 2024 |
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
