What is the kind of data is necessary to design a strainer? The solid maximum diameter is enough or I need a complete granulometric information? What kind of test can give me this data?
Thanks,
João
Posted 18 April 2017 - 08:56 AM
Thanks,
João
Posted 22 April 2017 - 01:19 AM
normally I include the usual process and mechanical spec's plus mesh spec's such as particle sizes, strainer type (membrane, mesh screens, drilled holes) etc.
Posted 25 April 2017 - 08:07 AM
Thank you for your answer.
Regarding the particle sizes, is there a need for a complete granulometric curve or only the information about the maximum diameter is enough?
João
Posted 27 April 2017 - 01:59 AM
Good day to you
The first step is to fix the process requirements to suit all the operating scenarios based on different ranges of feed stock, which could vary with quality and quantity during the life time of the facility being designed. Please describe your process system for better understanding and response
Higher Pipe Line Dia Specification In UnisimStarted by Guest_Praveen Perumandla_* , 27 Feb 2024 |
Pressure Drop Across A Suction Strainer Of A PumpStarted by Guest_nasim304_* , 21 Sep 2023 |
Stream Specification In HysysStarted by Guest_VLCENG_* , 17 May 2021 |
Basket Strainer In Vacuum SystemStarted by Guest_Sam6516_* , 22 Sep 2020 |
Suction Strainer Of Centrifugal PumpsStarted by Guest_Vegeta_* , 09 Aug 2019 |
