Can anyone tell me how types of valves in FEED stage are selected, which criteria or rules are used.
your prompt reply will highly appreciate.
regards
Posted 16 May 2017 - 05:07 AM
regards
Posted 16 May 2017 - 06:11 AM
PRO_ING,
Brief response; right valve selection in FEED stage would be done based on following criteria:
* Process Parameter; e.g.:
Flow
Temperature
Pressure
*Chemical Compatibility; e.g.:
Media
Percent of solid content
*Process requirements; e.g.:
On/Off vs. Control Service
Allowable leakage rate
Posted 16 May 2017 - 08:19 AM
Thank you Mr. Fallah for your reply
I read in some documentation that Gate , Plug and ball valves are suitable for On/Off service while Globe and Diaphragm valve are suitable for control service,
my concern is on which basis, we can favored the use of Gate valve on Plug or ball valve, and same for control service ( Globe or Diaphragm valve)
If you can cite some links or books in this purpose i'll be very thankful.
Wafer Check ValveStarted by Guest_Ali4269278331_* , Yesterday, 01:31 PM |
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Valve Cv InputsStarted by Guest_QuantumEng_* , 01 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Self Actuated Pressure Reducing ValveStarted by Guest_panagiotis_* , 16 Feb 2024 |
