Hello,
Currently we are having two sour water storage tanks as per which the overhead vapors are routed to H2S adsorbents and eventually to atmosphere. Since commissioning, the H2S adsorbents are getting saturated very fast leading to H2S and HC release to the atmosphere. For that, we would like to re-route the tanks overhead vapors to the acid gas flare header. However, this is not possible as the sour water tanks design pressure (350 mbarg) is less than the acid gas flare system (3.5 barg).
I would like to know if there is any mechanical modification that can be done to the low pressure tanks so that it can be considered as pressure vessels and then we can connect the tanks to the sour water tanks.
Thank you.
