Pressure Control Of A Pipeline
Posted 31 May 2017 - 09:10 AM
I have seen many huge shipping pumps with pressure control valves just downstream them and upstream the pipelines.
What is the reason of having pressure reducing control valves if there are flow control valves at the destinations? I see them as energy consuming devices only.
If there is a hidden reason to have them, how are they sized?
Posted 31 May 2017 - 10:07 AM
I doubt the valves at destination points are flow control valves - more likely they are (on/off) manifold switching valves and level control valves on storage tanks.
Flow control valves are still the dominant method in flow control applications. Depending on specific cases, VFD or mechanical speed variation devices may be employed with success.
Posted 01 June 2017 - 07:43 PM
Vegeta,
Your case is unclear.
Anyhow, Pressure regulating valves are applicable in a dramatic reduction of the pressure set the downstream pressure on a certain value but they cannot be used to regulate the pressure online.
On the other hand the flow control valves are capable to adjust the flow rate via changing the opening of the valve plug and obviously it might be associated with the pressure drop across the valve.
hope it helps you.
For further question, please let me know.
Posted 01 June 2017 - 08:30 PM
When you say "I have seen" do you mean that:
- You looked at drawing, control schematics or any place where it clearly state that those valves are for controlling pressure.
- Or that you observed automatic valves installed at pump discharge?
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Vapor PressureStarted by Guest_Hamza1111_* , 23 Mar 2024 |
