Estimating Ethylene Concentration In Solution
#1 MalMan
MalMan
  • 3 posts
Posted 11 June 2017 - 05:25 PM
Hello everyone,
I need your help in the following two scenarios:
- How to estimate ethylene concentration in Toluene, I have a reactor with a volume of 800 mL where 400 mL of toluene will be added, then, temperature is increased to 140 C and ethylene is introduced with a pressure of 10 barg. How can I estimate the ethylene concentration in toluene either by calculation or using Aspen Plus.
- The second case is similar but the solvent is Silicone oil (300 mL) and Toluene (100 mL), I was thinking of trying to estimate ethylene concentration in this case experimentally but couldn't really figure it out.
Thank you in advance ...
#2 Mahdi1980
Mahdi1980
  • 182 posts
Posted 12 June 2017 - 06:40 AM
You should find the binary curve of Toluene-ethylene in 10 barg and 140 C if the pressure of the reactor remains at 10 barg regardless of any reaction.
By aspen plus , you can simply find the materials from data and a state-equation such as Peng-Robinson and in simulation environment define a separator/vessel and then enter both materials into the vessel.
Note that the flow of ethylene gas to be specified.
So , at the outlets you can see the concentration of ethylene in both phases.
for further question, contact.
#3 MalMan
MalMan
  • 3 posts
Posted 12 June 2017 - 02:37 PM
Thank you so much Mahdi for your kind help.
Anyone have some ideas on the scenario with the oil ? the oil doesn't exist in Aspen, so it must be approached experimentally i presume ??!!
