Overcurrent Trip On Pd Pumps
#1 mccombe_kate@hotmail.com
Posted 20 July 2017 - 11:29 AM
Hi All,
Is it sufficient to use an overcurrent trip on a PD pump motor in place of an internal kickback or discharge PSV to prevent overpressure?
Thanks,
Kate
#2 Bobby Strain
Posted 20 July 2017 - 01:05 PM
No.
#3 fallah
  • 4,954 posts
Posted 20 July 2017 - 02:21 PM
Kate,
No, because although the motor has its own protection against overcurrent it's not intended to be tripped due to any process upset leading to discharge overpressure.
#4 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 20 July 2017 - 10:16 PM
Hi Kate,
In services involving slurries and heavy solid content as suspended impurities in the pumped liquid, the following can be adopted:
1. Provide redundant pressure trips (2 in series) to trip the pump on high discharge pressure
2. Provide combination of Rupture Disk and PSV (rupture disk upstream and PSV downstream)
3. Additionally as suggested by you an overcurrent trip may also be provided
In slurry service and service where the pumped liquid has high solid content PSVs will plug over a period of time, and unable to provide overpressure protection. From plant experience I can tell you that for Titanium dioxide slurry in MEG we had provided two pressure switches (transmitters) in the pump discharge line for overpressure protection and it worked fine. No PSV was installed.
