Hi Scientists and Engineers,
I would like to ask the following question I have about fluid flow. I have tried doing a force balance on it and I have also used Bernoulli's equation but to no avail.I just want to know if I'm tackling this problem in the right way or if I don't please help me. I was only given the density of mercury at 13600kgm^-3.
Saturated steam at 2 bar enters the top of a sealed cylindrical cavity and condenses, forming a pool of condensate. At the bottom of the cylinder is an exit pipe of diameter 5 cm. This exit pipe is open to the atmosphere, which consists of air at 1 bar. A cone of mass 1 kg blocks this exit, preventing any condensate from draining from the cylinder. The height of the cone that protrudes into the drain is 5 cm.
The volume of a cone of height H and base radius R is πR2H/3.
A manometer which is open to the atmosphere contains 50 cm of mercury. If the condensate level h is equal to 10cm, what is the height of the water level in the manometer with respect to the condensate level (i.e. in the diagram)?
Thanks.
Edited by Dudesons123, 09 August 2017 - 09:16 AM.
