Why Hydrodeslphurization inlet temperature should be above 370 C and bellow 400 C ??
Riaz
Posted 09 August 2017 - 07:20 PM
Riaz
Posted 09 August 2017 - 08:41 PM
Not all HDS operate in that range. Generally, lower temperature means less reaction. Higher temperature means more cracking and shorter catalyst life. You should check with your catalyst vendor / technologist for the criteria they used to define those limits.
Caloric Temperature CalculationStarted by Guest_bckesim_* , 10 Apr 2024 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
Temperature Cross Heat ExchangerStarted by Guest_Priolo_* , 12 Aug 2019 |
Cross Temperature In Heater Exchanger (Lng)Started by Guest_Yogan_* , 21 Feb 2024 |
Propane Product Temperature Correction FactorStarted by Guest_loggrrr_* , 20 Nov 2023 |
