Low Temperature Brittleness
Started by processEng2017, Aug 17 2017 08:02 AM
Posted 17 August 2017 - 08:02 AM
How to predict low temperature of a supercritical fluid in unisim during well startup when upstream of choke valve is at CITHP and min. ambient temperature and downstream is at minimum flowline pressure? Steady state and dynamic simulation.
Posted 17 August 2017 - 10:21 AM
do you mean the shut-in tubing head pressure ?
Posted 17 August 2017 - 04:26 PM
Most won't understand what CITHP is. You should avoid such expressions. First, try something. There is nothing special about super-critical fluids.
Posted 29 August 2017 - 01:46 AM
Sorry for using abbreviation. CITHP is Closed in tubing Head Pressure
Caloric Temperature CalculationStarted by Guest_bckesim_* , 10 Apr 2024 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
Temperature Cross Heat ExchangerStarted by Guest_Priolo_* , 12 Aug 2019 |
Cross Temperature In Heater Exchanger (Lng)Started by Guest_Yogan_* , 21 Feb 2024 |
Propane Product Temperature Correction FactorStarted by Guest_loggrrr_* , 20 Nov 2023 |
