Hello! I'm currently working on the process simulation of CO2 capture through Hysys, as an undergraduate project. The problem I'm facing is that with the current input parameters the absorption side of the process is converging and behaving quite correctly, but I'm having problems in converging the desorption portion (including the stripper and heat exchanger). The type of file can't be attached,so if someone can help of give suggestion, that will be appreciated.
Co2 Capture Simulation In Hysys
Started by Esfand, Aug 26 2017 08:49 AM
No replies to this topic
Posted 26 August 2017 - 08:49 AM
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , Yesterday, 06:05 AM |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
Linear Alkyl Benzene Sulfonic Acid Production (Labsa) SimulationStarted by Guest_Emranm02_* , 03 Mar 2024 |
Using Vector User Variable In HysysStarted by Guest_Ulbert Zsolt_* , 01 Mar 2024 |
