Dear Friends;
I am going to size control valve for minimum flow line of centrifugal pump.From pump vendor data I know minimum flow requirement(30% of normal flow). The question is about pressure upstream control valve for control valve sizing.should I use pump discharge pressure at normal flow or pressure correspond to 30% flow from pump curve?
p.s. i consider flow rate as NORMAL flow rate for control valve sizing.Does anybody advise to use this flow as maximum flow through control valve?
thanks in advance
Edited by processengineer1998, 01 September 2017 - 09:02 AM.
