Hi All,
Can any one have Cold box perilte filling procedure,please share with me.
Root
Posted 09 September 2017 - 11:07 PM
Hi All,
Root
Posted 10 September 2017 - 08:53 AM
Hello
The perlite procedure can either be manual or by using machine arrangements.
For smaller cold boxes like N2 generators or small scale ASUs, generally finished perlite products are sent to site in large jumbo bags.At site via the chain pulley arrangements, perlite transferred in small bags are mounted at different levels of Cold Boxes, where they are poured by people, after certain level of filling,generally, sticks or metal rods are used to even the surface of Perlite to prevent uneven distribution,slight tapping using the same metal rods on outside of the Cold box shell can also be applied.
For bigger cold boxes, generally, perlite ores arrives, they are heated and expanded and transformed into expanded Perlite powder, and via hopper arrangement is fed into different elevations of Cold Box.Intermittent levelling and tapping are relevant in this procedure too.
Bodhisatya
Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
Cold BoltingStarted by Guest_sfhh_* , 14 Aug 2023 |
Liquid Nitrogen Wash/cold Box Unit-CostsStarted by Guest_daraj_* , 24 Feb 2023 |
Hot Reflux And Cold Reflux In Distillation ColumnStarted by Guest_johneyissac98_* , 31 Jan 2023 |
Filling Tank With Hysys (Transient Process)Started by Guest_maximz_* , 09 May 2022 |
