Dear all experts
I would like to consult you that how can we verify flare knock out drum?
What criteria or parameter for verify ?
Best regards,
Salapao
Posted 26 September 2017 - 12:00 AM
Dear all experts
Best regards,
Salapao
Posted 26 September 2017 - 09:16 AM
What is it that you need to verify? Is this a new one in design? There is not a reliable guide for you to do so. Even the example in the API recommended practice is not correct. So be very careful.
Posted 26 September 2017 - 10:18 AM
Thank you for your joining my question.
I would like to verify existing flare knockout drum due to flare load increasing.
What parameter I need to calculate to verify existing flare knockout drum?
Best regard,
Salapao
Posted 26 September 2017 - 12:39 PM
You can visit my website where there are applications to help you. You should read the terms of use and instructions before you use any app. And look at the relevant API Recommended Practice. Part of the exercise is to determine the drum operating pressure at the maximum relieving conditions. Just use your favorite search engine to find me.
Posted 26 September 2017 - 08:27 PM
Salapao,
Its depends on basis or standard when your KO Drum have been designed, whether its using International Standard or Company Standard.
If your KO Drum design used API 521, you can assess its size , whether the drum size adequate for liquid droplet specify by API 521 (300-600 micron for Flare KO Drum). The other point, the drum hold-up time.
Posted 27 September 2017 - 10:20 AM
Bobby Strain, Pan Nainggolan thank you for your recommendation which is very benefit to me.
Salapao
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Back Pressure Of Elevated Flare Vs Ground FlareStarted by Guest_Sid__* , 04 Jan 2024 |
