Dear all
This is the first time I joint this forum. I would like to say hello to everyone.
I 've just been mobilized from Technology group to engineering group since June 2017. Actually, my experiences in engineering have limited. Therefore I need your helps.
I have some concerns about the bypass line/valve of control valve as below:
- Main line size and control valve size: 16"; Cv 2250
- Bypass line and gate valve" 6" only (instead of globe valve as i known);
- Fluid: crude oil, flowrate 1070m3/h at 50oC.
Last time, due to the control valve has problem and need to be isolated for maintenance. However, we did not want to reduce throughput of the refinery. The bypass valve was fully opened while control valve was isolated.
The velocity through the bypass line 6" at that time is quite high 17.7 m3/s against 3.66m/s (as refinery standard) or 4.5m/s as other standards.
Please advice if the above mentioned control valve configuration is correct? Do we need to resize the bypass line and replace a bigger bypass valve which are sufficient to handle the high flow-rate?
If modifications are not allowed, Do we need to reduce flowrate to ensure the crude velocity in the normal range?
