Pump Shutoff
Posted 23 October 2017 - 01:44 PM
I have a pressure vessel that is opearated at 2barg
And receive the feed from tank through feed pump (distance 6 km),
The shutoff pres.is 10 barg
Ihave to choices :
1.design the vessel for 10 bar because it is small (15 m3)
2-put pzv set at 4.5 barg (which is gona be a little bit complex for sizing the Pzv)
Posted 23 October 2017 - 01:59 PM
Ihave to choices :
Abdullah,
What is your problem about the system you described?
Posted 23 October 2017 - 02:07 PM
Ihave to choices :
Abdullah,
Should I do option 1 or option 2!?
Posted 23 October 2017 - 02:12 PM
Abdullah,
Either option can be selected; but option 1 is more reliable than the 2...
Posted 23 October 2017 - 02:21 PM
Abdullah,
Can explain why is more reliable !?
Posted 23 October 2017 - 02:30 PM
Abdullah,
Because in the system of option 1 overpressure scenario from pump shut off position would actually be removed.
Posted 23 October 2017 - 03:11 PM
You will find it best to design for the pump shutoff pressure. Especially if it is hydrocarbon material. You can check size and weight (KG, shown as cost index) of each choice with applications at my website. Just Google my name to find the site.
Posted 23 October 2017 - 10:50 PM
I can't find your website?
Posted 24 October 2017 - 06:15 AM
Use your favorite engine and key in "bobby Strain" , you should find Bobby Strain Group .
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Piping Design_ Pump PipelineStarted by Guest_anh.phungthai@boydensvn_* , 29 Feb 2024 |
Design Considerations For Cryogenic Submersible PumpStarted by Guest_heydari_* , 04 Feb 2024 |
Variable Speed Pump CurvesStarted by Guest_panagiotis_* , 27 Jan 2024 |
