Hi! We were tasked to design a kettle reboiler using HTRI. I already entered the necessary values for a BKU reboiler. However, even if I already adjusted multiple times to correct the warning message, there were 2 runtime messages that continuously popped out.
Errors:
1. The bundle entrance and exit vibration analysis is not available for TEMA K shells. The entrance and exit areas cannot be accurately define with information available in the program, and the nozzle flow rates often do not accurately represent the flow across the bundle due to fluid circulation.
2. For the ketteles (TEMA K or C shells), Xist assumes that the vapor in the two-phase fee bypasses the bundle, flowing directly to the outlet nozzle. If this assumption is incorrect for your case, the shellside heat transfer coefficient calculated will be conservative and the internal recirculation rate will be incorrect.
What does these errors mean? And how can I resolve these?
