Hi, I have an exercise to complete involving multicomponent distillation. The general overview of the problem is as follows, the feed to the column in n - pentane, n - butane and 1 - butene. The flow rates, pressure and composition of the feed and the distillate and residue is known and I have calculated the temperature of the condenser and partial reboiler. I have attached the questions I am struggling with - 6 and 7 - any help or advice on hoe to tackle these problems would be much appreciated! (Calculations from section A is referring to the temperature calculated for the condenser and partial reboiler).
Multicomponent Distillation
Started by firefox23, Oct 30 2017 03:13 PM
distillation thiele - geddes multicomponent distillation
Posted 30 October 2017 - 03:13 PM
Posted 30 October 2017 - 06:40 PM
In "Multistage separation processes 3rd or 4th edition" by Khouri under the title "Thiele-Geddes" there is what your professor is asking.
I am sure in your college library (that if I guess correctly is Cambridge in the UK) there is a copy.
Diked Area Around Distillation ColumnStarted by Guest_hysyshunter_* , 15 Apr 2024 |
Distillation Column Decommissioning ChecklistStarted by Guest_m.bhut_* , 08 Apr 2024 |
Reactive Distillation MtbeStarted by Guest_Michael Mitra_* , 15 Mar 2024 |
Vacuum DistillationStarted by Guest_hysyshunter_* , 12 Mar 2024 |
Distillation Column DiameterStarted by Guest_refluxraider_* , 12 Mar 2024 |
