Dear experts
within some olefin, NGL or LNG plants we need vaporization of dense fluid (dense phase).
I means we heat a fluid in liquid state but above critical conditions.
With such concept, it is possible to transfer a stream from liquid to vapor phase in single exchanger.
My first point is that during such phase change there is not reliable heat curve (physical properties).
Then different thermal rating software will have problem for heat transfer calculation and area prediction.
What is advice for such design.
Also, why when we work in under-critical condition, we should heat up fluid up to saturated vapor in single exchanger and then make it superheat in another exchanger. why it is not possible to assume such two exchanger in single shell and make superheat in single exchanger. when we use two exchanger one for saturated vapor and second for super heating, we have a system with different equilibrium in sub-section without separation and isolating.
Ghasem Bashiri
