98% H2So4 As Motive Fluid In Ejector
Posted 12 November 2017 - 10:50 PM
Your suggestions and information are most awaited..
Lead me in this topic
Posted 12 November 2017 - 11:36 PM
Eductors will work with any motive fluid and any educted fluid. Contact one of the manufacturers for information. Using a liquid to entrain a gas will not be very efficient. You will likely find a blower will be much more effective.
Posted 13 November 2017 - 08:10 PM
Posted 14 November 2017 - 06:20 AM
amit,
Ejectors with motive liquid are quite common in the chemical process industry. There are limitations to suction pressure if liquid is used as a motive fluid. These are also called as jet pumps. GEA jet pumps is a renowned vendor and can provide equipment with motive fluid as liquid and gas. Refer the link below:
http://www.gea.com/e...pumps/index.jsp
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Answered
Vacuum Ejector Pressure ControlStarted by Guest_himanshu.ch_* , 19 Mar 2024 |
Moc Selection For 98.5% H2So4 Tank Sludge CleaningStarted by Guest_lakshmi.narayanan_* , 02 Jan 2024 |
Sulfuric Acid Production / Partial Pressure Of H2So4Started by Guest_Jon K_* , 22 Sep 2023 |
