Hello, I'm trying to simulate an split type absorber using ASPEN. anyone know how to simulate it in one absorber or should I make 2 absorber?
Note: split type absorber is an absorber that have 2 different column diameter.
Posted 18 November 2017 - 12:09 AM
Posted 13 December 2017 - 04:28 PM
Hi Alex,
You should use two separate absorbers with different diameters in series.
Kind regards,
Satyajit
Posted 14 December 2017 - 08:57 AM
Hello Alex,
Maybe the two absorbers are to be operated at different pressures: the larger one runs at low pressure an the smaller one at the higher pressure.
Let the smart simulator simulate the absorbers under different operation pressures.
Best regards,
~Stefano Kim
Aspen Hysys - Creating A New Component And Defining PropertiesStarted by Guest_catiiiii_* , Yesterday, 11:42 AM |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , 27 Mar 2024 |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
