Methanol-Ethanol-Separation By Distillation
8 replies to this topic
#1 vikash_488
vikash_488
  • 5 posts
Posted 20 November 2017 - 07:26 AM
I have the feed containing about Methanol(96%), Ethanol (3%), Acetone(0.1%), Water (0.9%); all the compositions are in weight %.
The water can be maintained from 0.1% to 5% if it affects the product purity. The product purity required is about (Top): 99.95%, Ethanol: 50 ppm, Acetone :30 ppm, water: 0.1% and (Bottom), maximum possible weight% of ethanol. This is unconventional to those process in which Ethanol is the desired product; For us, MeOH is the desired product.
1st Question: would this be possible in single column with high no. of trays (40-60 trays)?
2nd Question: What would be most economical way to achieve such a product purity.
I am using ChemCAD for this simulation but not getting the purity of this level, The top for me is 99.85% MeOH, 500 ppm EtOH, 300ppm Acetone, Water: 0.1%. I am using UNIFAC/LATE in almost atmospheric condition. Will this be a good choice? I have many other unit operations which UNIFAC is suited to. I have almost the similar result with NRTL as well.
Please suggest me the ways.
Thanks.
#2 Bobby Strain
Posted 20 November 2017 - 05:42 PM
If you want higher purity you must use more reflux with a fixed number of trays.
#3 Tolinorton
Tolinorton
  • 73 posts
Posted 20 November 2017 - 06:09 PM
vikash_488,
Use SCDS module and Wilson as Global K-value Model
#4 panoskagiou
panoskagiou
  • 103 posts
Posted 20 November 2017 - 08:33 PM
Do you have azeotropes?
#5 vikash_488
vikash_488
  • 5 posts
Posted 21 November 2017 - 06:28 AM
Tolinorton:
Actually I am using SCDS only with UNIFAC, Wilson was not giving expected results.
#6 vikash_488
vikash_488
  • 5 posts
Posted 21 November 2017 - 06:30 AM
panoskagiou:
Not between Methanol and ethanol, but of course for ethanol-water.  That's why I am keeping 0.1% water in the feed to improvise the separation.
#7 vikash_488
vikash_488
  • 5 posts
Posted 21 November 2017 - 06:32 AM
I am already using high reflux ratio of about 8 with 30 ideal trays. Do you think I should go beyond this? I have already very high steam and cooling water consumption.
#8 Bobby Strain
Posted 22 November 2017 - 11:15 AM
Use more trays.
#9 panoskagiou
panoskagiou
  • 103 posts
Posted 22 November 2017 - 06:00 PM
I would like to ask you why you dont use design specs or a sensitivity analysis to see  what number of stages or reflux ratio you need?
