Hello, I have a distillation column to separate methanol and water. Methanol leaves the condenser at atmospheric pressure and saturated temperature. Is it necessary to further cool the methanol before it enters a storage tank. I have searched the forum and it appears that lpg, ethylene, propane are stored as saturated liquid, rather than subcooled. I was wondering if the same could be done for methanol.
Storage Tank Conditions
Posted 01 December 2017 - 03:16 PM
Posted 02 December 2017 - 01:34 AM
chessboss,
Please specify:
How much is the saturated temperature?
How much is the maximum ambient temperature?
Posted 02 December 2017 - 01:54 AM
Hi, the saturated temperature is 67C and the maximum ambient temperature is 40C.
Posted 02 December 2017 - 05:53 AM
chessboss,
Then it will be subcooled by ambient and can be stored either in a fixed roof under N2 blanketing or a floating roof tank.
Posted 04 December 2017 - 04:26 AM
Methanol is sub cooled to reduce vapour losses from tank. To sub cool materials like LPG you need a heat sink which will be at lower temperature compared to saturation temperature of LPG. In this case cooling water will be handy media to sub cool methanol.
For small storage (100 to 500 MT) you may go with fixed roof tank with blanket N2, however as the storage capacity increases, it will be economical to store in a Internal floating roof tank.
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Fan Laws For Centrifugal Compressors And Varying Suction ConditionsStarted by Guest_SickPuppy0_* , 25 Jan 2023 |
Standard ConditionsStarted by Guest_panagiotis_* , 06 Mar 2022 |
Butadiene StorageStarted by Guest_Mirzazada_* , 27 Mar 2021 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
