Gasoline Blending- posted in Ankur's blog
2
Hysys Hydraulic
#1 CS10
CS10
  • 23 posts
Posted 05 December 2017 - 02:39 AM
Dear Engineers,
I am doing the simulation for the pressure losses across the piping. I am using HYSYS to calculate the pressure drop. I am a bit confused with the specification to be input into the piping segment in HYSYS rating model.
As an example, if I have a pipe with the configuration going up (vertical pipe and horizontal pipe) and with a ball valve and an elbow. With this configuration how can I specified the pipe segment (consider the elevation changed).
Why do sometimes I got error message "Elevation Exceed Length"? How can I work out this error?
I have attached a sketch of the piping configuration.
I hope someone can help me with this question.
Thank you.
Edited by CS10, 05 December 2017 - 06:57 PM.
#2 serra
serra
  • 292 posts
Posted 06 December 2017 - 08:58 AM
I think process simulators are more suitable for pipelines,
for local networks you can adopt simplified models (accepting some limits)
or switch to specific software...
#3 CS10
CS10
  • 23 posts
Posted 14 December 2017 - 06:08 PM
Thank you serra
