As because pressure is active specification, flow rate stick on one. I wanted to give new flow rate, but when process is running it is again going back to the first flow rate. So I can change flow rate in dynamic to try different flow rates for my flow sheet ? for example if it is simple feed stream of nitrogen and oxygen passing through compressor to cool done . So pressure is 200 bar, temperature 100 K. Starting flow rate was 10kgmole per hour. Now I want to do at 20, but it is impossible to change it.
How To Change Flow Rate In Dynamic State In Unisim ?
Started by processengineer2018, Dec 07 2017 07:06 AM
Posted 07 December 2017 - 07:06 AM
Posted 27 February 2018 - 07:24 AM
Hi!
you cannot change it in such rude way. it is impossible. You can change parameters of your system (e. g. k value of valves) to change flow rate. but you cannot change pressure and flow rate simultaneously. you can understand reasons of it from pressure-flow equations
Posted 27 February 2018 - 10:11 PM
Increase the source pressure, open a control valve. That is how it happens in the real world.
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Unisim Dynamics Tech SupportStarted by Guest_Sam161_* , 16 Mar 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
Firewater Theoretical Vs Actual FlowStarted by Guest_stu_* , 25 Feb 2024 |
Higher Pipe Line Dia Specification In UnisimStarted by Guest_Praveen Perumandla_* , 27 Feb 2024 |
