I would like to set-up a factory to produce White Spirit, Industrial Solvent for Paint Manufacturers.
Could you assist to point me to which Raw Material is best to create this product (so I can look for its supplier) and could you recommend the machinery supplier that can supply all the equipment to set up a plant to produce White Spirit (if not then could you advice what specific equipment is required to set up the plant), Thanks.
Posted 08 December 2017 - 11:44 AM
Posted 08 December 2017 - 01:03 PM
This appears to be an academic question.
Posted 09 December 2017 - 06:29 AM
Take a look at the document attached or use your favorite engine.
Diked Area Around Distillation ColumnStarted by Guest_hysyshunter_* , 15 Apr 2024 |
Distillation Column Decommissioning ChecklistStarted by Guest_m.bhut_* , 08 Apr 2024 |
Reactive Distillation MtbeStarted by Guest_Michael Mitra_* , 15 Mar 2024 |
Vacuum DistillationStarted by Guest_hysyshunter_* , 12 Mar 2024 |
Distillation Column DiameterStarted by Guest_refluxraider_* , 12 Mar 2024 |
