Adsorption Column
#1 Erica789
Erica789
  • 16 posts
Posted 14 January 2018 - 12:34 PM
I am given a task and having problem that how should i approach it.
I am supposed to design an fixed bed adsorption column  for air drying using silica gel.I am supposed to report my mentor with following details: Break through curve, amount of silica gel required, height and diameter of column
All I have is Adsorption capacity vs Relative humidity chart, air flow rate (8000m3/hr), inlet air humidity(100% at 5deg C) and outlet air humidity(0.01% @20deg C), silica gel properties from perry's handbook.
please do reply..i am really stuck.
Erica
  • 6,334 posts
Posted 15 January 2018 - 06:37 AM
Consider the document attached to perform a mass balance and calculate the quantity of water to be removed per hour . I believe you can find good information in Perry's chemical handbook about adsorption and the rate of adsorption .
Hope this is helping you .
#3 Erica789
Erica789
  • 16 posts
Posted 15 January 2018 - 09:28 PM
Thank you breizh.
I'll go through this document and will come back if i have doubts.
