I have to design an absorption column that will be a packed column counter current flow. Ketene gas (coming in towards the bottom of the column) will react with liquid acetic acid (coming in at the top of the column). The product is acetic acid anhydride so this is a reactive absorption column. Considering my little experience with aspen plus I was not able to simulate the column. Instead I chose to do hand calcs on the column. The compositions of the incoming streams are essentially pure substances. The ultimate goal is to size and cost the column. Can anybody provide some insight of where I should go from here? Or any references that I can research?
Posted 28 January 2018 - 05:19 AM
Posted 30 January 2018 - 08:25 AM
Hi... You can refer Coulson & Richardson’s "CHEMICAL ENGINEERING Design" volume 6.
Posted 30 January 2018 - 08:31 AM
Please refer from page number 587 (Packed columns).
can you send your composition of gas stream, if you have any doubts?.
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Extension Reaction Kinetic In HysysStarted by Guest_Ulbert Zsolt_* , 29 Mar 2024 |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
Using Vector User Variable In HysysStarted by Guest_Ulbert Zsolt_* , 01 Mar 2024 |
