I need to know how to calculate the energy required to condense water from a N2 sweep gas at 1.1 bar and 65°C to decreasing temps, ie. 55, 45, 35...°C and what percentage of water would be collected. help!
Posted 01 February 2018 - 03:49 PM
Posted 01 February 2018 - 05:36 PM
Before you can start, you need to know if the nitrogen is saturated with water at 65 C. Then you can assume ideal behavior to estimate condensation at various temperatures. You should clearly know if the pressure you have listed is gauge or absolute. You can't get good answers without properly stating your question. Surely you have a textbook that gives you the procedure.
Acumulador De Vapor En Una Planta TextilStarted by Guest_Valeriacortez11_* , 15 Apr 2024 |
Coefficient Of Conversion Of Electrical Energy Into Thermal Energy ForStarted by Guest_amx_* , 03 Apr 2024 |
Vapor PressureStarted by Guest_Hamza1111_* , 23 Mar 2024 |
Answered
How To Defile Solar Energy Technologies In Aspen Plus?Started by Guest_m.ghaziasgar_* , 11 Feb 2024 |
Energy Loss In A Control ValveStarted by Guest_andrade_mcg_* , 02 Feb 2024 |
