Concentraition Process
Posted 04 February 2018 - 04:25 PM
Posted 04 February 2018 - 09:32 PM
Hello Arminer,
More input are needed to get a meaningful answer . What is the material you want to concentrate, what is the initial concentration ? what is the flow rate ? what do you mean by filtration ? I believe you are looking for a process similar to evaporation .
Hope this is helping .
Posted 05 February 2018 - 12:50 AM
The material is methanotrophs bacteria. the flow rate is 40 kg/min and the initial concentration is about 5%. by filtration I meant maybe pass the solution from a 1 micron filter in order to separate water from it and get to more concentrated solution. but I don't know how to clean the filter as it's a continues system.
Armin
Posted 05 February 2018 - 12:52 AM
oh and evaporation can't be done. I want something faster like mechanical dewatering, but the problem with that is that the particles get almost completely dry and I need to add water to it for the pasteurization step next.
Edited by Arminer, 05 February 2018 - 12:53 AM.
Posted 05 February 2018 - 02:40 AM
Check for centrifugal decanter or dewatering screw press machine . I'm currently using this type of equipment in China to replace a press filter to separate sludge from waste water .
Consider using your favorite engine to find out this type of equipment
Hope this is helping you .
Edited by breizh, 05 February 2018 - 02:50 AM.
Posted 05 February 2018 - 10:52 AM
And the research begins
Posted 05 February 2018 - 11:04 AM
Posted 05 February 2018 - 11:22 AM
http://www.nzifst.or...ology/about.htm
Go through this website you may find what you are looking for . You need to make an effort to tell us all the story and then you may get good pointers .
Posted 05 February 2018 - 02:14 PM
I just joined this forum and I'm not really familiar with it, sorry that I wasn't clear about the whole design at the beginning. They want to produce 1k tons of the bacteria per year.
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Let Down Vessel In Methanol ProcessStarted by Guest_Manue_* , 21 Mar 2024 |
Electrical Inputs From ProcessStarted by Guest_Chari_* , 06 Feb 2024 |
Recycling Of Working Solution In The Anthraquinone ProcessStarted by Guest_Has2riasat_* , 01 Feb 2024 |
