In most cases when designing a fired furnace, a stack will also be designed so to safely emit effluent flue gases.
Will this also be the case if the effluent gas stream is sent off to treatment for Carbon Dioxide removal?
Posted 12 February 2018 - 11:13 AM
Posted 12 February 2018 - 07:59 PM
Yes, because the vent gas will contain water, nitrogen, excess oxygen and low levels of CO2. The challenge is often that after CO2 removal the flue gas is much colder, and therefore stacks must be taller, or have induced draft fans to get higher exit velocities.
Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
Overpressure Scenario QuestionStarted by Guest_panagiotis_* , 08 Mar 2024 |
Falling Film Evaporator Basic QuestionStarted by Guest_panagiotis_* , 13 Mar 2023 |
Doubt In Mass Transfer QuestionStarted by Guest_guiromero_* , 11 May 2023 |
Question Distillation Column Transport PropertiesStarted by Guest_panagiotis_* , 05 Apr 2023 |
