Turbo Compressor, Wet Gas Simulation
Posted 15 February 2018 - 11:50 AM
Posted 15 February 2018 - 12:23 PM
with wet gas (in my opinion) if you know (or can estimate, for example from absorbed power and mechanical efficiency) shaft horsepower better to (estimate) polytropic efficiency from that value,
with wet gas there could be a non-equilibrium condition at discharge, other possible errors (in temperatures) can result from heat transfer, condensate draining etc. etc.
the same for turbines (in turbo compressors),
unfortunately, as far as I know, there are no standards (as ASME PTC10) for wet gas,
the polytropic model with phase equilibria in Prode Properties is accurate (about the same accuracy of reference model in PTC10) but you must use it with care... (the same for other process simulators, of course)
see also similar threads at cheresources...
Edited by PaoloPemi, 15 February 2018 - 12:34 PM.
Posted 15 February 2018 - 12:58 PM
thanks Paolo,
I have found a paper from NTU discussing that solution (i.e. consider shaft horsepower in addition to discharge temperature),
it seems interesting.
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , Yesterday, 06:05 AM |
Co2 Removal Membranes Between Compressor StagesStarted by Guest_Sinclc_* , 26 Mar 2024 |
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
Linear Alkyl Benzene Sulfonic Acid Production (Labsa) SimulationStarted by Guest_Emranm02_* , 03 Mar 2024 |
