Compressor Capital Cost Estimation
#1 adamsavine
adamsavine
Posted 10 March 2018 - 10:27 PM
Hi
To estimate capital cost of compressor, its power is needed. But how to obtain compressor power?
I am simulating a plant using Aspen hysys. To obtain compressor power, do i need to input performance curve or just input inlet outlet pressures? is the power value obtained by the latter way acceptable for compressor capital cost estimation?
  • 5,544 posts
Posted 10 March 2018 - 11:19 PM
adamsavine:
Are you a chemical engineering student or studying some other engineering discipline?
If so, then why haven't you been prepared to understand or even develop the method of calculating the power required by a gas compressor?
You say you are "simulating", but how can you qualify to do that if you haven't learned or been taught the basic essentials?
You need to take a course in thermodynamics or a similar unit operations course to learn the steps that are taken to increase pressure in a gas system before attempting to simulate it.  You can't simulate what you don't understand.   You have to learn how to walk before you can run.
#3 breizh
  • 3,866 posts
Posted 11 March 2018 - 12:38 AM
hi,
To support your work.
Another reference is Perry's Chemical engineers' handbook.
Good luck.
Edited by breizh, 11 March 2018 - 12:43 AM.
