Refinery Ccr Feedstock Heavy Naphtha Gc Analysis
Posted 09 April 2018 - 02:33 PM
Posted 09 April 2018 - 08:19 PM
Those isomers you listed are A8's. To determine them, I believe you need a mass spectrometer analysis.
Posted 10 April 2018 - 03:20 AM
Posted 10 April 2018 - 05:57 AM
No, you don't get it.
This is already your third topic about the same question.
There is no standard breakdown for SBP6 or A8 or whatever in your heavy naphtha.
Every heavy naphtha is different depending on its crude source, TBP cutpoints, fractionation sharpness in crude column, et cetera.
So stop fussing about it, assume something and move on.
A deviation of several percent between simulation and plant operation is normal.
Simulators are not as accurate as their vendors claim.
Laboratory analysis are not as accurate as instrument vendors and laboratory workers claim.
Plant measurements of especially flow rate, but also temperature and pressure are not very accurate either.
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Rating Of Existing Condensate Fractionator With New Heavy CondensateStarted by Guest_adnanaslam1988_* , 03 Feb 2024 |
Literature To Read For Refinery Oil MovementStarted by Guest_Noman97_* , 09 Nov 2023 |
Bulk Residence Time In Naphtha CrackingStarted by Guest_mehul_* , 19 Oct 2018 |
Naphtha PlatformerStarted by Guest_EngrHamza_* , 13 Jul 2023 |
