Dear Members,
I would like to check the following statement which is extracted from draft copy of API RP520 Part 2, Sixth Edition:
“Kinetic energy losses, including the pressure loss as a result of the flow impinging on the valve disc, are considered recoverable and do not need to be included in the pressure drop calculations. However, even when kinetic energy losses are non-recoverable, they are small in comparison with other losses and therefore can be neglected”
My question is how the kinetic energy will be recovered in the PSV inlet line (when kinetic energy changes across a reducer for example) and when it cannot be recovered. Is it related to the pressure build-up when PSV starts to open. Also, in the above statement, non-recoverable kinetic energy can be neglected so, can we neglect it in actual calculations especially when PSV is installed on atmospheric tank.
Your kind help is highly appreciated.
Menessy
