Dry Cooling Tower
Posted 03 May 2018 - 11:40 PM
If you have any explanation regarding this...please help.
Posted 04 May 2018 - 04:44 AM
A dry cooling towers is just an aircooled heat exchanger: a fan blows ambient air along finned pipes through which the medium that needs to be cooled flows.
It is like the radiator in a car: air cools circulating water/glycol which then cools the engine.
Posted 04 May 2018 - 05:12 AM
Can anyone provide book name or article which explains dry cooling tower working in detail.
Erica,
Also there are dry cooling towers working with natural draft in which warm air inside a tall tower tends to go up hence cold air will be sucked inside through the finned tubes containing the media which intended to be cooled.
By googling you will get many texts/articles/papers explaining about the dry cooling towers in detail..
Minimum Tower DiameterStarted by Guest_AnbIran_* , 17 Nov 2023 |
Sizing Of Cooling Water Pipe LineStarted by Guest_Asif Azeez_* , 08 Jan 2021 |
Heating And Cooling Circuit DesignStarted by Guest_AAZIZ_* , 20 Jan 2024 |
How To Calculate Cooling Rate Of CrystallizerStarted by Guest_snehchem_* , 04 Jan 2024 |
Cooling Adjacent Tanks In Separated DikesStarted by Guest_afmarat_* , 09 Nov 2023 |
