Dynamic Simulation
#1 halamcongtu
halamcongtu
  • 8 posts
Posted 04 May 2018 - 01:42 PM
I have a project in which my feed is pumped through some heat exchangers and then go into the column.But when I switch to dynamic, feed rate value was smaller than steady state value, about 5% or less.
  • 1,376 posts
Posted 04 May 2018 - 03:12 PM
Put a flow control loop in your dynamic simulation to get the flow you want.
#3 erwinfs
erwinfs
  • 12 posts
Posted 06 May 2018 - 11:10 PM
Agree.. I was once struggling with the flow when I firstly turned the simulation into dynamic mode. But when I put the flow control loop in the stream, I can get the flow as I wanted.
