Air Cooler Design Ache
software forair cooler design
#1 nivedita12
nivedita12
  • 46 posts
Posted 08 May 2018 - 12:14 PM
I am a process engineer .I needed to do a quick calc to find out the duty  for forced draft air cooler.
I see that ACHE software from Hudson products is not there anymore and has expired.
Does anyone have it for preliminary calculations,
Thank you
Nivedita
#2 Bobby Strain
Posted 09 May 2018 - 08:47 AM
You should learn to use the search engine at this site. And Google, too.
https://www.cheresou...zing-aircooler/
Edited by Bobby Strain, 09 May 2018 - 11:50 AM.
#3 nivedita12
nivedita12
  • 46 posts
Posted 10 May 2018 - 01:43 PM
Hi Bobby this is one is not working thank you so much though
#4 Bobby Strain
Posted 10 May 2018 - 05:04 PM
Nivedita,
I didn't check before I replied. If you go to the thread, I believe you will find a spreadsheet of some source. But I recommend never use a spreadsheet you are not familiar with. Your request was to calculate the duty. Is that all you need? There are lots of free programs to do that. But don't use any spreadsheet! If you verify your actual need, I and others can recommend software for you.
#5 breizh
  • 6,292 posts
Posted 10 May 2018 - 08:49 PM
Hi .
On top of the advices above , consider the documents attached to support your work .
