Dear friends,
I have a Lewa diaphragm pump which is designed for transferring a liquid Propylene mixture. Now, I have decided to apply it for handling white oil which density is 2 times greater than propylene and its viscosity is much higher than the liquid propylene ( Ro propylene =500 kg/m3 , mu of propylene =0.01 cP . Ro white oil mixture=1050 kg/m3 , mu white oil=50 cP)
Would you please advise if I can do it? if so, what are the effects of the new fluid ( white oil) on the performance and efficiency of the pump.
Edited by Mahdi1980, 23 May 2018 - 07:18 AM.
