Hello Every One
Recently we have commissioned non.phenolic sour water stripping unit at national refinery limited.
The unit is design at higher throughput by considering future need. it is almost three times bigger than the current/present normal operating capacity. Due to this over sizing, huge amount of energy is spent to run unit and some to product is recycled/re-routed to again feed tank to maintain turn-down capacity..
Management wanted to save OPEX so we are now keep the unit shutdown till feed tank completely fill and then running the unit at higher troughput (design capacity). So in this way unit is running for 1 day and remian shutdown for 2 days. Total running 12 days per month while it remain shutdown for 18 days per month. So the frequency of startup and shut down is 10-12 times per month.
We have calculated the OPEX after this optimization and it is saving our 70,000 ($)USD per month.
Your valuable opinion is required in the light of your huge experience. This way of optimization is good or not. Because we are thinking that frequent start-up and shutdown of units may challenged the equipment integrity and causing damage to equipment like reboiler (tube leakage) etc.
Kindly add your suggestion for improvement and negative impact of frequent start-up and shutdown of sour water stripping unit like salt deposition/corrosion or any catastrophic failure.
Best Regards
Muhammad Farhan
Process Engineer
National refinery Limited
Sulfur Block.
Edited by Art Montemayor, 10 July 2018 - 11:26 AM.
