Psv Tube Rupture Heat Exchanger Calc
#1 aider94
aider94
  • 11 posts
Posted 10 July 2018 - 12:22 PM
Dear everyone,
My case is heat exchanger - shell&tube type wax/wax+solvent.
Parameters (only pressure considered):
Shell design pressure: 14 bar(g),
Shell side operating pressure (in/out): 4,0/2,5 bar(g),
Tube design pressure: 9,5 bar(g),
Tube side operating pressure (in/out): 6,0/4,5 bar(g).
Tubes diameter 20 mm.
Density is needed too I suppose...
My knowledge of PSV devices tells me that if lower pressure side to higher pressure side is equal to 10/13 ratio, then I don`t need to consider PSV (ASME/API says condition that hydro test pressure of lower pressure side has to be higher or equal to higher pressure side).
In my HX I have lower design pressure side on the tube side and higher design pressure on the shell side. A ratio isn`t enough to meet the 10/13 rule (9,5/14 bar(g)).
Questions:
1) Is a tube rupture case is taken under consideration in case that shell side has higher design pressure than the tube side?
2) How to calculate such PSV relief (I`m asking for advice for calculating PSV relief for tube rupture case for both sides when shell side/tube side pressure ratio is higher than 10/13 and inversely). When calculating relief do I use design pressure or operating pressure?
Aider
#2 Bobby Strain
Posted 10 July 2018 - 01:04 PM
Is the shellside protected by a relief device? And for what cause? If so, what is the set pressure. Which side is being cooled?
#3 aider94
aider94
  • 11 posts
Posted 11 July 2018 - 12:35 AM
Bobby,
Thanks for your response.
I'm considering if I need to protect SS or TS by a relief device such as PSV. Shellside isn`t protected by a relief device, because I see no sense in securing shell side (design pressure of SS is higher than TS. A situation when tube ruptures and tube side fluid flows into SS won`t be able to crack/break SS).
I have hot fluid on the shell side (in/out temperature 202/129 degC) and cold fluid on the tube side (in/out temperature 96/126 degC).
#4 latexman
  • 1,686 posts
Posted 11 July 2018 - 07:00 AM
A P&ID would help us help you.  Is hot fluid liquid or gas/vapor?  Is cold fluid liquid or gas/vapor?
#5 aider94
aider94
  • 11 posts
Posted 12 July 2018 - 01:17 AM
Both sides contain in/out liquid phase. Sorry, but P&ID is covered by a confidentiality clause and I can`t upload... Basing on my descriptions, it is possible to imagine my case.
Both questions #1 and #2 could be answered based on all the information I wrote I think.
#6 Pilesar
  • 1,384 posts
Posted 12 July 2018 - 08:46 AM
My answers to your questions:
The engineer must consider all reasonable scenarios that would result in exceeding the maximum pressure of the vessel. The evaluation of the tube rupture case may or may not result in vessel overpressure.
Relief valves should be calculated by those who are trained and competent. At a minimum, you should read and try to understand API 520 and API 521. For additional explanation I recommend the Crosby Engineering Handbook https://www.emerson....-us-3923290.pdf
Sizing relief valves is serious business. Vessel overpressure has resulted in thousands of deaths.
#7 diogovalente
diogovalente
  • 4 posts
Posted 17 August 2018 - 04:35 PM
In my understanding the shell side do not need to be protected for tube rupture since it is the high pressure side. The tube side would need since the hydrotest pressure is lower than the shell side pressure. Again, that is for tube rupture, other scenarios (like fire or blocked outlet) still might need to be considered on the shell side.
The relief load calculation for this one could be done several ways, the most common would be the following:
  • Two orifices flow based on the tube diameter;
  • An orifice and a tube flow based on the tube diameter and length.
With more data I could provide a more accurate help.
Diogo
