Vessel Vacuum Due To Pressure Control Failure
#1 Butterfly
Butterfly
  • 73 posts
Posted 12 August 2018 - 02:22 PM
Dear all
I have a distillation column, operating at low pressure (less than 1 barg). I have light hydrocarbons on top, and the scheme is: total condenser, with hot bypass pressure control. Main PCV is upstream the condenser, and the hot bypass line includes a differential pressure control valve.
If column pressure drops, the main control valve should close. My question is: can a failure in the pressure control loop lead to a vacuum contition in the column? The same way that if the pressure increases and valves does not open when required, I could have an overpressure.
Thanks for your help
#2 Technical Bard
Technical Bard
  • 382 posts
Posted 12 August 2018 - 10:47 PM
Why would you put the main PCV upstream of the condenser?  That is an odd configuration.   Usually pressure control of the column is on the accumulator vessel.  For a total condenser, the pressure is controlled by the vapour pressure at the condensing temperature.
#3 breizh
  • 4,048 posts
Posted 13 August 2018 - 02:04 AM
2 documents about controls on distillation columns .
Hope this is going to help you.
#4 Butterfly
Butterfly
  • 73 posts
Posted 13 August 2018 - 03:24 AM
Thanks. My scheme is similar to Figure 9 in the first attachment (in the scheme the PCV is upstream the condenser), with additional DP control in the vapor equilibrium line..
#5 breizh
  • 4,048 posts
Posted 13 August 2018 - 05:54 AM
Hi Butterfly ,
You should check the design pressure of the tower and the failure modes for PCVs .
You may want to review your existing HAZOP .
Edited by breizh, 13 August 2018 - 08:26 AM.
#6 Butterfly
Butterfly
  • 73 posts
Posted 20 August 2018 - 03:04 AM
Thanks for the advice!
