Throttling In Between Pumps In Series
Posted 14 September 2018 - 10:50 PM
Is there any reason to have a letdown control valve at the discharge of booster pumps feeding shipping pumps?
I'm asking because I've seen a system to load tankers that has such configuration. The operation philosophy of that system is to keep the booster pumps running irrespective of the demand while the number of operating shipping pumps is dependent on the demand.
Posted 28 September 2018 - 03:53 AM
Dear:
By throttling valve the booster pump discharge pressure will be adjusted and automatically regulate the booster pump as flow demand.
Posted 28 September 2018 - 08:08 AM
Vegeta,
The booster pumps is mostly due to provision of adequate NPSH for shipping pumps. Hence letdown control valve is rightly applied between booster and shipping pumps to provide a fixed NPSH for shipping pumps irrespective of shipping demand.
Posted 28 September 2018 - 09:05 AM
Doesn't look like good engineering practice to me.
Using Similar Check Valve In SeriesStarted by Guest_vsnlbom_* , 22 Dec 2023 |
Vibration Of The Pump (Reciprocating Pumps / Plunger Pumps)Started by Guest_vsedhuraman_* , 06 Oct 2023 |
Aspen Edr - S&t: Process Side Series / Cw Side ParallelStarted by Guest_mitch22_* , 06 Feb 2023 |
Switching From Parallel Mode Into Series ModeStarted by Guest_ahmed abd elmonem_* , 17 Jan 2023 |
Variable Speed Pumps Operation.Started by Guest_panagiotis_* , 11 Oct 2022 |
